Date:    3-14-2010
Number of Hours:    1.00
Brief Description:    Finished Leading edge filler blocks
Finished all the leading edge filler blocks. I also did the 4 filler blocks for the 1" thick ribs. These were a little bit harder. The router would not adjust to 1" high to router these blocks. I had to use the sanding disc to sand them to shape. I was very careful to not sand into the form block and they came out pretty good.
