Date:    11-21-2008
Number of Hours:    1.00
Brief Description:    inertia reel fitting
Fitted inertia seat belt reels to the diagonal root tube. Because the seat belt mounting hole is quite a bit larger than the AN4 bolt used for mounting, I decided to add a bush cut from compression tube.
Before bolting th diagonal tube into position I inserted a compression tube for the seat belt mounting hole for maximum tightness of the mounting bolt.
