Date:    8-5-2008
Number of Hours:    2.00
Brief Description:    check fitting of aft hull mount angles
Check fitted up aft angles and drilled mounting holes in transom. Drilled holes in angles for rudder and tailwheel extension cables. Once completed touched up paint where it had been scratched off in the fitting process.
