8-17-2008 |
1.00 |
upper compression strap for vertical fin compressi |
Made new upper compression strap from 2mm alloy sheet for compression strut on vertical fin as springs for trim assist cylinder are hooked onto this and factory supplied is made from very thin alloy and it is possible that the springs may wear through over time. |
