Date:    9-17-2008
Number of Hours:    3.00
Brief Description:    cargo area decking
After experimenting with different thiicknesses I have decided to use 2 x 5mm flute board glued together as my cargo deck. To ensure that it is supported I am adding various aluminium angles to the frame and hull for support.
I found that making templates out of cardboard was the easiest method prior to cutting out the flute board. Once a template was finished the deck was cut out from 5mm flute board
