Date:    5-10-2010
Number of Hours:    3.00
Brief Description:    fuel tankleak repair
Found small leak in top left hand corner of fuel tank due to a pin hole in the weld during manufacture. Repaired with special 2 part epoxy supplied by tank manufacturer. After repair tested OK by spraying fuel onto the repaired area from the inside. Filled tank and checked again for leals and checked OK.
