Date:    6-8-2010
Number of Hours:    2.00
Brief Description:    fittting flaps
Fitted flaps. Very confusing re how to attach the tie rod to the flap horn as no instructions in the manual. Ended up using an AN-14a bolt with an 18mm spacer to straighten up the angle between flap slave horn and flap horn. A shim was added to underneath of each hinge to gain clearance from the trailing edge of the wing.
Fender washers were added to the rod ends in case of failure.
