Date:    4-25-2009
Number of Hours:    1.50
Brief Description:    Trim motor
I started the day working on the trim motor and its respective access panel. I had primed the various parts early in the morning before I went to work out. By the time I got back they were dry, so I re-checked the dimple and reset a couple of holes. Then I riveted the support flanges to the access panel. They hold the motor at the correct angle. Then I riveted them in place anc attaced the motor. I double checked the fit on the elevator and everything was fine. So back to the elevator.
