While I waited for comfirmation on my plan for the trim motor access I started work on the vertical stabilizer. Having done this before the work went pretty fast clecoing the rear spar and stiffner together and then adding the ribs; next step drill the ribs and spars to size. Before too long I had the skin on the skeleton and drilled all the holes to size. Had to stop to help Julie with some critter fencing for the garden. Just before I left Steve Barnes stopped by so we discussed my trim motor access panel decision. He agreed with my plan, so I will get back to the left elevato and finish the trim motor right after I finish the VS.
