Date:    6-24-2007
Number of Hours:    5.00
Brief Description:    Horizontal stabilizer continued
Today I finished all the fabrication for the left side of the HS. All of the tasks are a repeat of the right side, so the work went much faster. I did drill one set of holes the incorrect size. In a momemt of confuson I drilled the holes in an end flange of a rib too large. Fortunately the oversized holes are still within the distance tolerances for rivets. That is the distance from the edge, I will just move up to the next size rivet. The next step is to take everything apart and sand, debur and prime.
