2-22-2015 |
2.50 |
Weekend update - 01 |
Finished tapping the last two holes for the fairing under the horizontal stabilizer. no photos of that work. I drilled access holes through the ribs under the co-pilot's seat for the roll servo wire run. I also fabricated a small avionics shelf to place under the co-pilots seat for terminal blocks. Not sure if I will use it. I am not convinced it is necessary. |
