Date:    12-24-2014
Number of Hours:    4.00
Brief Description:    More fiberglass work
The two horizontal stabilizer tips are closed, finally..... They both need final sanding, mounting and priming. I plan on mounting the HS tips after the New Year, then finish prepping for primer. Next will be mounting the elevators and checking clearance between the elevator arm and the HS tips. I am sure there will be some minor adjustments to be made.
Almost done with this tail. I will be nice have it mounted again, hopefully for the last time.
