Date:    12-20-2014
Number of Hours:    2.00
Brief Description:    Fun with fiberglass - VS tip
I had done a layup inside the vertical stabilizer tip to repair a void and hole. Everything looked okay until I started sanding. I found another void. To get to good material I sanded and sanded and sanded. You can see the area in image one.
In image two it is ready for more glass. I did another layup inside and two on the outside to fix the void AND try to get the tip close to its original shape. I thought I took a picture after the layup work but I guess not.
Isn't fiberglass fun?
