Date:    1-4-2014
Number of Hours:    3.00
Brief Description:    Rudder bottom cap
Worked out the fit of the rudder bottom fiberglass cap. At least it finally straight and aligns with the rudder. I ended up cutting much of the front portion away to ensure clearance between the rudder and the aft fuselage. I am going to fiberglass the top portion and you can see in image one I have glued a foam dam in place to begin that process. I need to put in the aft light mounting fixture and wiring.
