Date:    12-21-2013
Number of Hours:    2.00
Brief Description:    Fiberglass tips - 02
I also worked on the VS tip. While sanding I discovered either a void or a crack, not that it matters at this stage of the game. You can see the hole I ended up with as I sanded the void down to see its limits. Another task added to the list.
