12-11-2013 |
4.00 |
Tail finish work continues - 05 |
Worked on the various fiberglass tips of the empennage. The rudder is riveted on as is the left elevator tip. The right elevator tip is clecoed in place. I am concerned about edge distance, but will deal with that tomorrow. After all the tips are riveted I will blend them to the surrounding metail. If you have not worked with fiberglass, there is a lot of sanding. And I am just beginning. |
