Date:    12-9-2013
Number of Hours:    3.00
Brief Description:    Tail finish work continues - 02
Back to the cold hangar again. Today I installed the HS attachment bolts, torqued and marked them with torque stripe. Moved to the rudder and checked the jam nuts on the bearings, torqued and marked them. Put the VS back on the aircraft and installed all the bolts, but still need to install nuts and torque. No pictures today.
EDIT I took some photos before starting work on 12/10
