Date:    3-25-2016
Number of Hours:    5.00
Brief Description:    Engine update - 01
Well, there are no updates posted for the engine. It is hung on the aircraft and most of the systems are installed.
1. All the sensors (oit temp, oil press, fuel pressure and manifold pressure) are installed.
2. Fuel lines are installed but two (on order.)
3. Carburetor is installed
4. Magneto was pulled and an IRAN was completed.
5. Fuel pump was removed due to a fitting change and reinstalled.
6. Alternator and starter with new wiring were installed.
