12-7-2012 |
3.00 |
Canopy hoop covering |
In the zodiac canopy construction video they mentioned using rubber heat shrink to finish off the canopy hoops from their rough finish. I tapped the existing holes in the hoops to accept metric screws and then used a heat gun to shrink the rubber. After that i used a soldering iron to make holes through the rubber into the underlying holes. after that i rivted the various aluminium attach points on. Came out really well. |
