Date:    6-21-2009
Number of Hours:    5.00
Brief Description:    Installation of Rear Carry Through Spar
In this element I drilled the rear spar carry through down to the base of the fuselage and used a wooden jig to ensure that teh rear spar angle was correct prior to making the cut out and installing the rear spar attach points.
I was not happy with the structural rigidity of the rear spar carry through and so I replaced it with a thicker material having Alclad at Lanseris bend precisely according to the plans.
