Having trouble getting the trailing edge straight. Drilled holes in the angle aluminum for a straight edge. Wants to pucker at some point. I may have to take the end ribs rivets out to help distribute the unevenness. Out of town for a several days so will work on it when I get back. I also have to fix the inboard edge of the trim tab. I need to bend in the tabs a little more. Shouldn't be too hard but we will see.I also have to switch the rudder counterweight. Seems that I put in one of the elevator cw's there. The rudder cw is longer by about 1/3 it seems.
