Date:    11-15-2010
Number of Hours:    3.00
Brief Description:    AP roll servo, landing light.
Puttered about a good part of the afternoon on this. Finished install for servo and wire harness in the right wing. Hopefully complete, minus the pushrod from the control stick to the belll crank. Also made hole for leading edge landing light. Drilled holes in ribs and mounted nutplates for the light itself. Will remove pink string as I believe there is no more wiring to install in the wings.
