8-29-2009 |
3.10 |
Finished Riveting Tail and Continued w/ Flap Syste |
I took a couple of hours today to finish riveting the last two bulkheads in the fuselage. I had to use a couple cherry-max rivets in the hardest to reach places in the bottom, but the rest turned out fine. I continued with the flap system by priming all the parts. Before doing so, I had to trim the center channel cover at the aft end in order for the flap motor channel to fit, then I reprimed it as well. |
