Date:    1-14-2009
Number of Hours:    2.00
Brief Description:    Tail Spring Mount and Fuel Tank Bracket Supports
I picked up the powder-coated tail spring mount and installed it in the aft fuselage between the rear-most bulkheads. I installed the strut for the wheel ahead of time since it will be more difficult after everything is riveted in.
I moved on to finishing the forward fuel tank bracket supports. Several quickbuild rivets had to be drilled out for the stiffener installation. I then took the previously fabricated parts and fit/drilled/dimpled/countersunk as necessary. I removed them for priming and will reinstall them with clecos only for now.
