Date:    3-7-2010
Number of Hours:    2.50
Brief Description:    Continued Forward Fuselage Deck
Today I deburred and dimpled the forward top skin as well as the top of the firewall. I also fabricated the L & R vent brackets and started trimming one corner of each of the vent adapters/ventilators as required using the drill press and belt sander. I also went ahead and primed the inside of the elevator control tube by spraying and turning it to coat the entire inside.
