7-8-2008 |
1.00 |
Worked on Rudder Skeleton |
I fluted the tip rib and counterblance rib and then clecoed and match drilled the rudder spar and tip rib. I clecoed and match drilled the counterbalance skin to the ribs. Finally I clecoed the R-901R&L rudder skins to the skeleton along with the R-916 trailing edge in preparation for match drilling. |
