Date:    4-19-2008
Number of Hours:    2.00
Brief Description:    Primed HS Skins and Dimpled Skins
I primed the inside of the horizontal stab skins and began dimpling the skins as well, using the hand squeezer to start with. I also cut a tab in each of the rear spars for the elevator hinge stops (not listed in instructions...only diagram!), edge finished and re-primed these areas.
