Date:    10-20-2005
Number of Hours:    4.00
Brief Description:    leading edge
Finished up the landing light tonight and did a smoke test on it. Works good. Also had Jenny come out tonight and helped rivet the leading edge to the wing spar. She did a good job when you consider she had to buck rivets that she could not see. After the leading edge was all done I mounted the fuel tank.
