12-31-2019 |
4.00 |
Continued R. Fuel Tank - Rib 7, Fuel Sender & PU |
Riveted Rib 7 and covered heads with Proseal. Installed Fuel Sender and Fuel Pickup on Cover. Tested Sender - 030 to 248 ohms. Torqued PU fittings to 110 in-lb. Didn't have to move the inside nut to make the anti-rotation Bracket fit correctly. Covered a few more heads in the tank in Proseal. Next: - Finish covering the rivet heads inside the tank. - Make sure the end ribs are fully sealed inside focusing on the tip. - Install Baffle - Install Z-Brackets - Install Cover with PU and Sending Unit |
