12-28-2019 |
4.00 |
Riveted Rib 1 Reinforcement, Installed Vent |
Drilled hole for Vent Line in Rib 1 (7/16"). Riveted the three nutplates for the inboard fuel tank rib. Used a backrivet set and the tungsten bar. Much better than the Left Wing. Installed the vent line, cut, deburred, and flared it. Came out nice and clean. Had to do it twice since I left the nut and sleeve off the first time. Riveted the two plates on Rib 1 on the R. Fuel Tank and gooped it all up with sealant. Next: - Finish Vent Line and Fuel Pickup Fittings. - Seal & Torque Fuel P/U and Sender to Plate (off the tank). - Seal and Rivet Rib 7. - Install Baffle - check sealant remaining to see if I have enough to do it. New sealant being shipped now. - Install Fuel Pickup Cover & Sender |
