7-12-2019 |
7.00 |
Right Aileron - Finish |
Finished the Right Flap. - Riveted the Spar and Hinge Used the my homemade angled pull rivet tool. Worked well. Left a little smile on the rivet heads, but not bad. MUCH better than not using it. Checked twist. The Left Flap was almost perfectly flat. The Right Flap had a little less than 1/8" twist/rocker. |
