6-16-2019 |
5.00 |
Started Ailerons |
Sorted a mix of rivets in the morning and then reorganized them into a parts organizer. Much easier to find the rivets now. Moved the Right Wing Spars into the house so I can finish up the Left Wing (Aileron and Flap). Started the Ailerons today. Separated, shaped, and smoothed the edges on all the Stiffeners. Smoothed the corners on the Spar ReinforcementPlates. Match drilled them and the Stiffeners on the Left Aileron Skin. Fluted the Nose Ribs. Need to Match Drill the brackets with #12 bit (for the bolts) and catch up the Right Aileron to this point. |
