Date:    11-25-2018
Number of Hours:    8.00
Brief Description:    Left Fuel Tank - Nose Reinforcement, Fuel Cap/Flan
Match Drilled both Left Fuel Tank Nose Reinforcement pieces to the Rib. Used 6 #4 Rivet Holes and the single #6 Rivet Hole (match drilled from tooling hole). Also, added the 9/16" hole for the Fuel Pickup elbow.
Match drilled the fuel drain flange.
Enlarged Fuel Cap hole to fit the upgraded caps/flange. Used a 2.5" Hole saw then a scotchbrite wheel to get the final 2.55" dimension. Came out looking very good.
