11-19-2018 |
9.00 |
Riveted Main Ribs to Main Spar and Rear Spar of Le |
Riveted all the Main Ribs of the Left Wing onto the Main and Rear Spars. Mounted assembly to Wing Stand. Spent a long time leveling and securing it to the stand and trying to get the shop setup so I can work without bumping into everything. Clecoed on all four Main Skins. Had to drill out several rivets on the Tip Rib. Kept getting a gap. Finally acceptable. Also, found a bad rivet in one of the Root Rib where it rivets to the Main Spar Web. Will drill out and replace tomorrow. LONGGGG, but productive day... |
