10-20-2008 |
5.00 |
Collect Wing Kit and Perform Inventory Check |
Went to collect the RV12 Wing Kit from Krugersdorp Airfield where the Shipping Container was delivered. It was 1 Hour drive there and 1 Hour drive back home with the kit. Back home I opened the Crates and inspected parts for damage. No damaged parts, but wingtip close out skins where bend a little bit along the long thin pieces, by the big box moving around in the crate. I need to check the plans where these skins go and if it will cause any aesthetic problems. The Wing Kit crate looks empty but has many layers and layers of skins packed into the bottom, sandwiched between cardboard pieces to protect them. Vans know how to pack. Every time you think you’ve reached the bottom of the box, then there is another layer of skins. I completed checking the inventory against the packing list, and did not find any part missing. |
