Image 1 shows the Trim Access Reinforcement Plate back-riveted to the Lower Left Elevator Skin. Seven nutplates were riveted to the plate before being assembled to the skin. The Trim Cover is installed temporarily to check for fit. Everything looks pretty good. I will wait to receive some items by mail before closing up the left elevator and finishing the trailing edge. I want to wire the servo using shrinkalbe butt splices and a rubber insulated clamp to hold it in place first. Also I need some snap bushings.
