5-20-2019 |
3.50 |
Left Fuel Tank |
Continued fitting ribs for the Left Fuel Tank. I found the process at least as difficult as the L Leading Edge. I made a more solid wooden jig to place on top of the rear rib flanges to aid in squeezing with the ratchet straps. I also found the use of drift pins was very helpful in aligning the holes. I had to cut the day short to do other things. |
