Date:    11-1-2019
Number of Hours:    2.00
Brief Description:    Riveted Trailing Edge of Right Flap
I used the Cleveland trailing edge rivet set to squeeze the rivets. I didn't put the trailing edge on the table, but instead used an aluminum angle drilled for the trailing edge to keep everything straight. This worked very well as you can see with the laser alignment tool.
