Date:    12-25-2018
Number of Hours:    2.00
Brief Description:    Trim Tab
The trim tab is finished! The special squeezer set from Cleveland Tool is very valuable for making a trailing edge perfectly straight. The shop heads turned out fantastically. The hinge alignment was spot on. One recommendation is not to forget the rivet right by the trim horn. I had to use a pop rivet, no big deal.
