Date:    11-1-2018
Number of Hours:    5.00
Brief Description:    Fitting Vert Stab Ribs
Deburred and used a scotch brite pad on the dremel to prepare the surfaces for primer. Test fitting all the pieces together and straightening the ribs.
Drilled the #12 holes in the hinge points of the rudder hinges. This was to resize after the powder coating.
