12-30-2008 |
4.00 |
Rewired Roll Autopilot Servo |
When I built the Wings two years ago I did not leave enough wire for the roll servo to make it in one run from the servo to to the panel. I since then did have the wire on hand so I replaced the wire and made up a new db-9 connector. Note to self, removal of the servo is pretty much required if the db-9 connector is to be disconnected from the servo. |
