3-12-2008 |
5.00 |
Fuse assembly - 103 - Rudder misc |
In was not happy with the rudder pedals friction so I worked on the center support block and added a backplate to spread out the compression load on the block evenly. Much better! I also finished drilling the mounting holes for the vert stab to the fuse rear. I also match drilled the center support bracket to the vert stab. |
