3-11-2008 |
6.00 |
Fuse assembly - 102 - Rudder Linkage/ELT |
Since the rudder was neutral, I measured and made up the links to connect to the pedals. I also noted the the bottom of the rudder will interfere if I ever switch to taildragger mode. I modified the rudder so the tailspring will not interfere. I also drilled and cleco'd the ELT tray in place. |
