12-31-2007 |
4.00 |
Fuse assembly - 81 - started working on eyeball ve |
Molly and I worked on the eyeball air vent mounting layout. I bought the stein air versions and obviously they install differently than the vans setup. The first thing I did was make the mounting ring plate to attach the vents too. This required use of my POS harbor frieght butterfly hole cutter. Oh well, got it done. |
