6-25-2007 |
6.00 |
Fuse assembly - 18 - Brackets, engine mount, left |
Received a piece of 0.063 plate from vans and recut the 684 corner brackets. The ones from vans are too close on edge tolerances. After finishing the bracket construction I removed the firewall and match drilled my new engine mount while it was convienent. I then removed the left side skin and finished dimping all remaining holes since everthing is match drilled at this time. |
