Date:    7-4-2006
Number of Hours:    7.00
Brief Description:    Right wing LE and fuel tank installation
Set the right wing LE in place and installed the Right wing fuel tank. This is time consuming due to the alignment being critical at this time between the LE and the tank. Once the alignment is set and the wing is assembled the clearance between the LE and the tank is permanently set.
