4-4-2019 |
2.90 |
Sealing the Tanks |
Today I finished the right fuel tank! I riveted the baffle to the skin, putting sealant in each rivet hole prior to inserting the rivet. I moved on and installed the tank cover plate and the fuel sender. Then I went back and put a dollop of sealant around each rivet head on the baffle. Hopefully no leaks! |
