8-30-2018 |
6.60 |
Trimming the Stiffeners, Riveting the Left Elevato |
I did a lot of work on the elevators today. First I had to prep the replacement skin for the right elevator. I smoothed the edges, match drilled the holes to the understructure and then dimpled all the holes. I also ordered new stiffeners so I trimmed and prepped those as well. They were then dimpled. I primed the new skin and stiffeners as well as the new trim tab skin that I ordered. All with Sherwin Williams P60G2. I back riveted all of the stiffeners to both elevators. I finally ended up perfecting the back riveting process and ended up using a pressure of about 50 psi on the rivet gun. I bent the trailing edges of both elevators using the 2x8 brake and the hand seamer. They both came out really well. I riveted together the understructure for both elevators. |
