Date:    9-22-2009
Number of Hours:    3.00
Brief Description:    Prime Panel and start stabilizer fairing
Tonight I primed the panel. Used the same 'Metal Ready' etchant and the last of the 'self-etching' primer I had. Primer seemed to stick ok. Next up for this: paint.
I also started working on the fairings that go between the vertical and horizontal stabilizers. First thing I did was screw a piece the material to the bench and get a decent polish on it. Then I marked and cut the pieces out, making sure to cut out a left and a right. I then bent one into shape, but I'm not sure if it'll be good enough, as I got a slight crease in it. Have to see tomorrow if I can get this crease out. Image 1 shows the fairing.
