Date:    8-25-2009
Number of Hours:    2.50
Brief Description:    Glare shield and panel
Spent a few hours tonight working on the glare shield and the panel. My plan is to paint both of these the same color (silver) instead of the carpet thing done by most builders, mainly to save weight.
Before I get too far, I'll need to decide what all the components are going to be on the panel so I can cut the proper holes. I've made up my mind that I want to use the Stratomaster Enigma color EFIS by MGL, and the V10 VHF transceiver also by MGL. I'm not sure what transponder to eventually install, but one requirement is that it'll have to fit in a standard size hole. I also have made up my mind that I want to install resettable fuses in the panel along with lighted rocker switches.
More decisions to follow.
